needs new mids
JAZN
i need some mid's with killer midbass, enough to blend in well with my horns and ported idmax.
here are my amp specs:
MA Audio m283i 2ch
# Frequency Response: 20 Hz - 20 kHz
# Full Mosfet Circuitry
# Selectable Bass Boost @ 50Hz
# 50dB Channel Separation
# 90dB Signal Noise Ratio
# 22K Ohm Input Impedance
# 200mV-2V Input Sensitivity
# THD
# Selectable Crossover: LPF, FLAT, HPF
# 50Hz - 250Hz Low Pass Filter
# 50Hz - 250Hz High Pass Filter
# Selectable Bass Boost (0db, 6dB, 12dB)
# 2 x 100W Rms @ 4 Ohm Stereo
# 2 x 200W Rms @ 2 Ohm Stereo
# 1 x 400W Max @ 4 Ohm Bridged
# Fuse Rating: 25A x 1
could yall suggest something? theyre most likely gonna be in the doors IB (although i may eventually make sealed doorpods). budget is $200 give or take. should be a 6.5-7". mounting depth isnt a concern. used is fine tambien.
i would but idk about power requirements.thanx for lookin out j.
ksin is running his off 90w off a arc 4150 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
but Id stay at 150 rms if if was me though
with 100w (assuming your amps doesnt do anything more than that non underated)
from what I have used or heard
1) dls iridium 6.5" around 200 used
2) focal k2p 6.5"around 225 used
never heard them but over at DIYmobileaudio.com
the current rage are the 8 ohm SEAS CA18RNX
supposedly they are very efficient from 80 to 3000hz IB and are about 60 each from npdang
they are VERY light (the basket is open a but so you have to protect it from water somehow, and 3" deep, buddy O mine bought a pair hasnt installed them yet though
happy hunting bro
JAZN
JAZN
SoCAL
Kali77
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
