Need a amp for two pioneer pro series 12's...dual 2ohm's... theyre 1000watts rms..a piece..but my buddy needs a amp that wont require a electrical system upgrade..so around 1200rms or a lil higher would be good..any suggestions ??
I am going to be pushing my 2 10" D2 Pioneer Premier subs with my Hifonics 2608d amp running at 2-ohm, so each sub will be seeing 850rms, which my subs are rated for 800rms each. Take in the fact that my amp is overrated some, so should be spot on, if not a little under powered.
The new Hifonics amp supposedly does rated, and can be bad for under 400 smacks new. Might want to check into that.
