need your help Pioneer 5900ib installation
kentb
hi guys, i installed a pioneer 5900ib in my sister's 2001 mitsubishi galant
attached the ground wire to the mounting sleeve that is connected to a metal part in the dash.
it doesn't turn on.
so i took the ground off, and wiggled some wires then it worked!
i was putting it back and it turned off again.
so i tried wiggling more wires and it seems to turn off and on.
that is with or without the ground connected to the mounting sleeve.
i tried isolating the wires one by one b ut i can't find it.
idk, what do you guys think?
do you have a DMM?
yes. what should i do?
hmm how about the plug going to the deck? also did i read right you grounded the "sleeve" or chassis to metal frame of car? or was it the deck's body?
plug going to the deck fits nicely, not loose or anything.
i grounded it to the mounting bolt which i believe is connected to the frame.
the wierd thing is its still turning on and off even if the ground wasn't connected.
kentb
kentb
Las Vegas
southwest713
