need to upgrade electrical?
Chow
13
MN
Do I need to upgrade my electrical and get a capacitor or other items. I will be installing a 15 l7 using a hifonics bxi1206d amp running 0ga kicker pkd1 kit.
If I just do the Big 3 will I be safe? I don't want to kill a battery or alternator. I will be installing everything this weekend.
that amp doesnt use that much powah... just do the big 3 NO capatater plzkthx
so 1200w at 1ohm really is not that much? I thought that 0ga pulls a lot more than just a 4ga.
So I shouldn't have any issues if I hook everything up as long as I have the Big3. My friend said that he has been stranded a few times but then got a power block or something to distribute the flow of power to the system and the battery.
So is the big 3 necessary for me to complete before i hook everything up, or can I wait a few days later because I think I need to get more 0ga wire. and a fuse
Well you will be getting voltage drops during thosse few days, I wouldn't do it but as long as it isn't prolonged I don't know that it would hurt it that much if at all. Get the big 3 in ASAP.
the wire size has nothing to do with how much powah its using... and i have no idea what yo friend is talking about
no, its not immediately necessary... it will be fine if you do it a few days later
should I use the same size fuse that came with my kicker kit (300A) for the big3?
i assume you're talking about a fuse between the alternator and the batttery? ALWAYS fuse according to the wire rating i.e. in case of an overload, you want your fuse to burn up before your wire does
so would a 150 or 200 work if I don't have a 300a fuse?
Thanks for all the help guys!
Wire does not pull power. The amps pull power. The wire allows the power to be pulled. What you said is like saying that having a bigger wallet makes you more rich. Or like saying that putting on bigger clothes makes you fatter. Get it?
The reason you use bigger wire is to allow more current to be drawn by the amps. If your wire was too small, it would burn (or your fuse would fry if you used the correct size)
For now, yes. It is perfectly safe, there is just a higher chance of you blowing it if you crank it.
And you don't need a capacitor. Very few people know how to properly implement a cap, and for the majority of applications it's a waste of money.
How many amps is your alternator? If you experience dimming, you may need a new one.
Chow
Chow
MN
XanderMoser
