Need some opinions. Welcome all ideas.
BUMP
How long did it take to do that drawing? And don't say 5 minutes, cause I know that's a lie!
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Yes the drawing took me about 5 min. I draw them all teh time and got pretty good at it. As far as the wiring, i don't understand why you think it's so much. It's a diagram that is drawn to show detail. Not exact scale footage of wire. The reason i just used the link in the original post is because i am on an INMARSAT connection. If you don't know what that is it is a commercial and military satellite link and it's slower than mollasses on a cold day. It takes an hour just to get online and make one post. guess that shows my dedication to the forum. What i would like is opinions of the setup. What do you like and dislike? Obviously my goal is SPL but still musical. I'm considering a changable port for comps.
um.
you underestimate how hard 160 is.
with 4kw and a single 18 in a daily driver i do not think you will get above 155 to be honest.
but good luck.
um.
but good luck.
Well it's actually closer to 6000 if not more depending on voltage. The amps are 2400 strapped @ 2 ohm with 12.8 volts in. I'll be running each strapped pair at 1.5 with hopefully close to 14 volts continuously. I expect 1500 from each amp at the very least. I've decided to go with the 2 15s based on the comments about putting all that power on one sub for daily. I'm still coming up with ideas as far as a changable port. I may end up just doing one like meade. We will have to see. It's going to depend on how deep i can make the box. A changable port probably cant use any interior wall as a port wall so i will have to figure that out. Probably tuned to high 40s or low 50s. Does anyone know what the resonating freq of a 4 door 2006 blazer is? There is also going to be like 300 sq ft of deadener in it.
I’ve personally done some stupid single 4” VC 15’s in trunk cars (for customers), and sometimes a single 15” on stupid wattage is stupid...
19
248
250
601
515
germanyt
germanyt
Ponchatoula, La
germanyt
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
