Need some help
DeLaRosa25
Ok so I will try to give you the full story here. I am somewhat new at all of this so cut me some slack.
Car- 1994 Camaro with moonsoon. Which was bypassed with rockford fosgate wiring. Which was wiring to the stock wireharness from best buy. Using a Alpine 9883 head unit.
Car is going to the junkyard so wanted to put the head unit and speakers in my 98 Camaro with moonsoon.
The 98 Camaro had a pioneer head unit in it. Powered by an alpine amp (which all 4 speakers were ran off of).
I took out the amp,wires,and the 2 rear speakers (fronts already had pioneer). I replaced the two rear speakers with my alpine ones from previous camaro.
I attached the harness to the alpine one (93-02 camaros are interchangeable), and wired all 4 speakers up.
After each speaker was installed I tested the speaker and every single one worked..
I button up the install and went to test it after a hard day and not the head unit would not turn on. I switched back to the pioneer just to test it and it turned on fine. Alpine wouldn't. Realized my car battery died. After a quick jump start alpine turned on fine, but would not give me any sound now.
I checked all of the wires and they are crimped and good condition. All where they are suppose to be. Rest the head unit. Checked all fuses with a test light and they all work. Checked harness wires and pin are straight and everything is good. Even changed out a speaker to see if it was blown and nothing. Cranked the volume, went through the settings to see if i missed anything and I didnt
I am completely stumped. All four speakers worked fine and all 4 decided not to work anymore?
This is one came from my 94 camaro going into my 98
This harness plugs into the stock one, or the one already in the car that was used with the pioneer for wiring
Here is my wiring. Everything checked out good
Cliff points
Hopefully all of this makes sense. Mainly want to figure out why the 4 speakers will not work now, but worked perfectly fine before I finished the install? Wiring is all good,speakers work,volume turned up,head unit play with in settings,fuses are ok, reset head unit.
so basically i tranfer everything over, everything is hooked up exactly how it was in the 94 camaro, just no sound..its driving me nuts. if I had the money to take it to a professional and have them fix the problem I would, but no job and gotta do it myself.
so you have the speakers wired directly to the back of the stereo? did you run new wires to the speakers or are you using the factory wires. I cant tell how you have the red wires connected to the harness itself. do you have the red wires and the harness wires connected to the alpine? Did you check to make sure the alpine internal power for the speakers is turned on?
DeLaRosa25
DeLaRosa25
Saginaw,MI
CrossoverOre
BP1Fanatic
BP1Fanatic
