Need some Help...
Boominator
Soundwave Master
I have a 2 channel amp that is stable at 2 ohms. My question is that I have 2 (4 ohm) (DVC) 15" subs. Can I wire each sub to 2 ohm's and use both seperate channels on the amp without bridging and still show the amp a 2 ohm load? keep in mind that this is not bridged and I plan on going 2 ohms per sub to each channel on a 2 channel amp 2 ohm stable.
Yes. Since the subs are DVC, the 2 coils can be wired in parallel to be a 2-ohm load to the amp. Then you'll have a 2-ohm load on each channel of your amp, one for each sub.
Boominator
Soundwave Master
Boominator
Las Vegas
kross
