Need some help
ChucklesTc
i am currently running a single
12" pioneer 3004 spl sub 4ohm DVC 1000watts rms 3000peak,
kenwood 8512D 1100watts peak 300W x 1 @ 4 ohms, 550W x 1 @ 2 ohms.
I have the sub wired down to 2ohms, and my gain is set at 4v
Running of stock headunit with LOC
my problem is that after about 45mins at higher levels my sub cuts out, then like a few mins later turns back on or if i turn the volume down low comes back on.
I just purchased this amp because this was happening to my system with previous setup so i thought the old amp was bad. What can be causing this?
I went through all wiring and double checked grounds and proper connections.
could it be the LOC gain setting not correct?
I am a little disappointed in the loudness of the sub also, from what i have read on the forum the 3004 spl can get loud.
any suggestion to solving the problem?
ChucklesTc
ChucklesTc
Chicagoland
ChucklesTc
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
