need some advice on my setup, mmats, hifonics, kinetik
MmatsproRodeo99
wassup guys finally got off my lazy *** and started my wall for 3 15" dreads, I have a optima Yellow under the hood, 0/ga big 3, stock 90 amp alt, single run of 0/ga to rear kinetik 2400, powering bxi2006 brutus run @ 1.33 ohms. should I change anything? also what is the benefit of running multiple amp set ups for the subs? the dreads are rated at 1500 rms which ill be in that zone with the brute riht?? also whats so wrong with top ported walls? I have 20 cubes give or take b4 subs, port and bracing which should be right at the recomended 4.5 cubes per sub with my math any advice or critiscism is appreciated...
how do you figure? they will run a 1.33ohm load on amp should be close to 1700 watts right?
your running one amp for all 3 subs? the rms for one sub is 1500rms or all 3 is 1500rms? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
honestly i would use 3 bxi20006's instead of 2. i will get flamed for this but they are a little overated and im sure the dreadnauts can take one of those amps per sub with proper gain settings. but that plus the electrical to back up almost 5000 watts is probably out of your budget. would be one hell of a groundpounder //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
MmatsproRodeo99
MmatsproRodeo99
Lake City, FL
MmatsproRodeo99
