Need helping building a box
I'm looking to build a box for an American bass xfl-1022. I have bass box pro but am unfamiliar with using it. Have all the specs for the sub if needed I can post them. I plan on powering this sub at 1 ohm on a c.a.b 1600.1.
Put up the specs... I'll give it a whirl... and post the modeling... I'll also need vehicle space measurements...
Well... I've modeled it and it was a b*tch... to get enough port area and be able to keep it short enough to fit into the box... I've modeled it right at 1000 watts input so the CAB might deliver a little more than that... Oh well... All I need is vehicle measurements now...
Here it is...
I had a hard time finding the port area/length that would work with that power...
I'm still learning so any feedback is appreciated...
It's peaky but to smooth it out required a SMALL box with an external LONG vent... or just sealed of course...
38 hz tune...
363
304
680
549
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Jlashley0723
Jlashley0723
Ny
shredder1
    May 10, 2024
3toneEYZ
    May 10, 2024
