need help
luo@twt
nj
hello I recently did some up grade on a system in a 2017 Nissan maxima. it has a lc4 line converter a eq one 4 ch kicker one 2 ch kicker 8inch in front doors 8inch in rear deck tweeters on dash tweeters in rear deck the car sounds great . but for some of reason the volume kinda sounds like it goes up on its own. does this car have some thing that will make the volume go up because of wind noise from the subwoofer and if it does how can I disable or fix this problem? any information would be a great help. thank you
unless your hu has like a drive eq (my hu has it) my wifes last 2 cars have it from factory, volume goes up as u speed up to be louder than road noise only other thingg i can think if if alt sending more volts as u hit gas..
thank you for replying. the car does have speed sensitive volume . the function is of but it still sounds like it is still on.
luo@twt
luo@twt
nj
luo@twt
