Need help
SikGli
I have a jetta gli
And I'm fixing to do my system
I had this system on my old truck
2 Memphis c3
Jl audio 1000/1
1 set of infinity kappa 6.5 component set
1 6.5 infinity kappa reg
Jl audio 360/4
Epicenter
And old school pioneer 13 band mp3 cd player
Optima kennitik battery's and a PAC
all this was in a blow threw set up
Now I don't really know about Memphis
But I wanna put another 12 c3
How does Memphis work
Odd number or even numbers ???
And is the jl audio 1000/1 is it to big for the speakers
And another thing I was using a 4g wire and
My voltage would drain big time from 14 down to 1/4 in the gauge and amp would turn off
And another thing the ohms would show on the amp
What do ya think
if the woofers are dual 4 ohm then you can wire them to 2.67 which would be good for the amp.not sure what the woofers will take tho. also you need 0 gauge wire for that amp,it draws alot of power then take the wire to a distro block and a very short run of 4 gauge into the amp.use the 2nd battery and do the big 3 and you should be ok.
SikGli
SikGli
Houston tx
mylows10
Mike Mccabe
