need HELP....
str8_up
OK i just got a amp from WhiteIce specifically Bxi2006..
i had runs of 2gauge along with the Remote line and RCAs run from when i had my front stage put in.
Now i hooked everything up and it powers up just fine.
I wire it to my IA DP and no movement from the sub.
(doesnt go into protect at all)
the gains have been played around with and nothing.
is it the AMP or the RCA runs???
OK i just got a amp from WhiteIce specifically Bxi2006..i had runs of 2gauge along with the Remote line and RCAs run from when i had my front stage put in.
How is the sub wired and was it hooke dup to another amp before WITH NO CHANGE IN WIRING?
If you re did the wiring ion the box just make sure it is connected correctly. I have seen people trying to do parallel and they just make a big loop and the sub will still read a resistance.
ok....
cause i know the sub works.
and i know the amp is powering....
but i cant take out my HU to check the RCA's because i dont have the metal stick things.
I dont even know if they are hooked up to my HU.
so I'm going to try this today. and if it works then i will know its my RCA's.
EDIT: i dont have the sub in the box i was just testing the amp.
so i had it hooked up different ways but nothing all the same.
str8_up
str8_up
Spartanburg,SC
john denver
