need help
  • Thread starter rankinsf
  • Replies 0
  • Views 359
rankinsf
I am running
Details: 2 kenwood subs
» 12" 4-ohm component subwoofer
» injection-molded polypropylene cone with rubber surround
» power range: 35-150 watts RMS (peak power 600 watts)
» frequency range: 30-600 Hz
» sensitivity: 91 dB
With a Sony Xplod Mobile 2/1 Channel Amplifier - XM2200GTX
Features:
1200W Max Power
200W x 2 RMS into 4 ohms, 20Hz-20kHz @ 0.1% THD
500W x 1 RMS into 4 ohms, 20Hz-20kHz @ 0.15% THD
CEA-2006 Power Compliant
Variable 50 - 300 Hz low pass filter
40 Hz EQ boost
MOSFET output stage & power supply
RCA & speaker level inputs
Line level thru-put
Specifications:
Max Power (Watts): 1200
Ad Hoc Power into 4 ohms, THD%: 200 x 2, 0.1
Ad Hoc Power into 2 ohms, THD%: 250 x 2, 0.15
Bridged into 4 ohms, THD%: 500, 0.15
Signal to noise ratio (dB): 100
Frequency Response (Hz): 5 - 50K
Input Level Range (V) Line level input: 0.3 - 6
Input Level Range (V) Speaker level input: 1.2 - 12
Operating Voltage (V): 10.5 - 16
Current Drain at rated output (A): 48
And this is my problem the FN subs keep cutting out after a while
rankinsf
rankinsf
Idaho
rankinsf
