hemiscott 10+ year member No Mo Hemi 868 0 Tampa Bay Area Feb 22, 2007 #16 Possibly, just dont go crazy with gain and volume... Or if you are worried about it, just wire it at 8ohms and be done wit it.
OP bass4life16 10+ year member Registered User 95 0 kc Feb 22, 2007 Thread Starter #17 ok so will that 8 ohm diagram that hemi posted work
O orioles26 10+ year member Senior VIP Member 243 0 Severna park, Maryland Feb 22, 2007 #18 yup, the bottom one is the one you want.
OP bass4life16 10+ year member Registered User 95 0 kc Feb 22, 2007 Thread Starter #19 ok thanks alot guys
OP bass4life16 10+ year member Registered User 95 0 kc Feb 22, 2007 Thread Starter #20 oh when i wire it to the amp do i put one wire on the negative and positive of the same channel or one on each channel
O orioles26 10+ year member Senior VIP Member 243 0 Severna park, Maryland Feb 22, 2007 #21 a positve of one channel and a negative of the other channel. On the amps ive ever bridged there was a little line showing you which two to use.
OP bass4life16 10+ year member Registered User 95 0 kc Feb 22, 2007 Thread Starter #22 ok i just looked and there is so thanks again
O orioles26 10+ year member Senior VIP Member 243 0 Severna park, Maryland Feb 22, 2007 #23 You also might want to read and learn how to set the gains if you dont know. http://www.caraudio.com/forum/showthread.php?t=63933 should help.
