Need Help!!
BenTLocK
BlaZeN4Sho
got my boss amp today and tryed hooking up but blowed both fues that came with amp.. but tomorrow i plan on going to pep boys and geting more.. so i know i hooked up something roung for it to blow so i need help..
http://www.bossaudio.com/AMPS.data_/CHAOS.html
my amp is the last one "REV-155"
i got the amp hook up to the bat and i got the ground hooked up..
i got the 2 chanels hooking up to the 2 pyramid subs..
wen i first hooked it up befor the fuses blown the sound coming from the speakers seemed to be weeker in sound.. so then i played around and ****ed up..
its in a chev s10 no cab... factory head unit..
if you chould help me out and tell me what other wires i need to hook up that would make my day..
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
this happen to me when i tried to install my system for the first time, i accidently touch the positive and negative wires together and it blow the fuse on my amps. not sure this could be your problem but something to look at....
I don't know your situation with your vehicle but with mine... When I first got it, there was a cheap stereo that the owner before me had put in, and the moron had like a 1 amp fuse in there. I know your situation is slightly different but try bigger fuses.
BenTLocK
BlaZeN4Sho
BenTLocK
Manchester, NH
gmc89
