Need Help!
Lunatic07
I have a 2 Channel SPL 3000D Class D Amp n its connected to 2 12's Audiobahns which each has 550 RMS and hits good as hell. Now my question is I want 2 keep 2 of my 12's n get a 15'' Audiobahns IMMORTAL wit 2000 RMS. Can my amp hit all 3 of dem and sound good or do I need another amp for just dat sub, if so wut other amps would give its true power to dat sub?
That just depends on the impedance of your current subs and the IMMORTAL sub that you plan on getting. If impedance were not an issue, the answer is simply yes. You can have 2 12's and 1 15 run off the same amplifier in the same car. If you have Dual 4ohm 12's right now, which most Audiobahns are, then you have a problem unless you wire them to 8ohm each and get a DUAL 1ohm IMMORTAL wired in parallel to .5ohm then wired in parallel to the two 12's.
Lunatic07
Lunatic07
Daytona Beach, FL
camry_tuner
Mike Mccabe
