need help
Maybe a bad RCA cable? try diconnecting them and see if it quits.
Also, check over your speaker wires (for the sub), if those are touching ground you could get the same noise.
It sounds like your RCA's might be pinched. I would check them and make sure they aren't. If they are, you need to replace your RCA's with a new set, and watch where you place them.
sometimes the noise is soft and sometimes it is loud....yes my wires are correct...also my mids and highs go off when i play the radio but when i play a cd it comes back on
i didn't even touch my ground.....it was already grounded so i just hooked it up...i dunno guess i'll have to pay for someone to look at it which i didn't want to do i wanted to learn how to do it on my own
Well, it might have not been grounded very well. They way to learn how to do things on your own is to not give up and keep trying different things that will fix the problem. So, don't give up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pcolasfinest
Go ahead, drink it in.
pcolasfinest
florida
pcolasfinest
