need help with wiring setup
ut. I recently purchased two alpine type-r 10" subs, swr- 1043d (600rms/1800max each). I have never wired dual voice coils before and.both coils are 4ohm. I wanted to wire them in full parallel, but that brings it to a 1ohm set-up. Im worried about the strian on my electrical, but really want the subs to hit hard and deep. Any suggestions on wiring setups, an amps to run this system?
If you want to run full parallel at 1-ohm, then just make sure you use the correct gauge wiring and a monoblock amp that is rated to drive a 1-ohm load.
Do you have an enclosure for those subs yet? What type and specs?
Do you have an amp yet or are you looking for a recommendation?
If looking for recommendation, what is your budget for an amp?
gordo1408
gordo1408
ontario, canada
Jepalan
