lol that is what I was thinking as well. they have another website though that list all of their products.. it is in transition still. batcap.info is the website. idk, what do you think loop? think adding a 400 or an 800 in parallel with the 2000 in the back would increase the difference in the drops? I think im going to go back and redo my big 3 again this weekend too. Whe I first did it I wasn't near as good with big wires as I am now. they might not be as "tight" in the crimps. if that is the case chances are they could have some corrosion too....also, would running a straight ground from the back battery to the front improve my voltage? right now I have my second battery grounded out on the chassis in the back. appears to be a good ground but idk.
Do not simply add in another smaller battery. That is not going to get the job done. If anything, stick that 2000 under the hood and get yourself a bigger rear battery. I still think you have something wrong with your setup though. If Ray says that thing can do the 1500wrms, then you should not be having these issues.
Here is what I would do. Get that 2000 tested this weekend. Make sure it passes a load test. That is for sure priority numero uno.
If it does pass the load test, then simply put it back in the car. Make sure your amps are wired directly to the battery (both power and ground). Make sure those connections are solid. Inspect any fuses that are in use. Now that all of that is all good, time to test things out.
At this point, you should test the audio without the engine running and I would also install the front battery back in place, but I would remove the inline fuse between the front and back battery. That way, you know that the front battery is not the issue. The amps will run only off the 2000 and the front battery will only be powering the HU.
Now you need to test the voltage at the amps power and ground inputs with your DMM. You need to check the voltage with the music playing at 1/4, 1/2, and 3/4 volumes. At each level, jot down the voltage.
This test should take you no more than 5 minutes I would assume. That should not fully drain the battery by any means. If it does, then you know it is for sure way too small to handle your system.
In contrast, I have just under 1000W RMS in my system running off my HC1400 under the hood and I can run my music at 3/4 volume (engine off) for hours and my car will easily restart. So if cannot run your music for at least an hour, I would say that 2000 is not up to par.
//content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
The
ebay site is better.
LOL! I guess if you simply want
ANY info at all, it works fine. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Forget the fact that it is inflated and erroneous info at best. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I like picking on you Buck, you are a good sport
