ahardy17
i just finished installing a new box in my car, seen here: http://www.caraudio.com/forum/car-audio-build-logs-*new*/440304-two-memphis-m3-12s-mcd1-1100-first-ported-box-5-cubes-@-36hz.html
and i've got the worst turn-on/-off pop and thump i've ever heard in my life.
the amp remote wire on my HU's harness says "to amp remote in 0.3A max" and i have that going through the relay straight back to my sub amp then the second amp is piggybacked off of that one, with a short wire between the 2 amps. i've done that before with no problems.
i had a blue neon on the amp rack running on the same remote power but removing that didnt help.
i've tried using shorting plugs on the amps and theres no noise when i use those so i'm pretty sure it's not the amps.
i have the amps well grounded, theyre grounded about a foot apart from eachother with star washers under the ring terminals on clean bare metal
a loose power wire contacted my RCAs a while ago in the process of upgrading and i cut a couple inches off the ends and re-soldered the ends on. but i dont think thats the issue because i have one brand new set of RCAs and its the same with them
there's a fuse on the back of the HU and thats fine too
i'm at a loss here i've exhausted all my resources and searched old threads for answers to no avail.
i also upgraded my big 3 in the process and the new ground comes a tad closer to the power wire than the old one did, but i dont think that makes much difference, just giving the details so you guys know what the setup is like.
one other thing i did was eliminate the harness wiring for factory speakers because there was no room behind the HU. no clue what kind of effect that might have had but i thought it was harmless
any input would be greatly appreciated...this is driving me crazy
