Need help with Sony headunit watts?.
HiFiFan15
Hey everyone I need a little help with my Sony headunit. My stereo says it has 52watts x 4 channel. The headunit is the Sony cdxgt320.
I want to connect only 2 speakers. Can I get 104 Watts to both speakers if I only use 2 speakers and not 4?.
I hope you all can help I really need the information and have been trying to find out for a long time now.
I , honestly, watched someone twist all speaker outs to one center dash speaker once. They had the nerve to demand a full refund when it didn't sound good. I'm not joking at all.
internal amp ratings are bigger liars than all the politicians in the world combined. if you want cheap power that isnt going to win any SQ contests, but will give you the power youre expecting from the head unit, but dual makes some tiny and well tested amps that can give you the juice you need for your purposes
Here is some information about how head units are built, what those amplifiers look like, and how they are configured.
Head units use a small amplifier IC (integrated circuit) to power speakers.  This chip is about the size of a quarter, in total.  Consider the size of an entire aftermarket amplifier and you get an idea of what expectations you should have for this tiny circuit.
For example, the picture below is of a pretty standard amplifier IC in a Pioneer-made head unit.  It would have ratings similar to that of your Sony.  In this picture, you see the IC removed because I was making some modifications, which aren't important to this discussion.  That IC does ALL of the speaker amplification for all four channels.
Next, consider the topology of the amplifier IC.  It already has bridged/balanced outputs, meaning there is signal on both the + and - wire.  You can think of the amplifier IC like an 8 channel amp that has already been bridged down to 4 channels.  For this reason, it is not possible to bridge a head unit any further.
Lastly, the typical rating method of IC amplifiers (used in home or car audio) is if one channel can produce rated power for one second, they can label the IC as having the capability of producing that power into any of the four channels - even if that isn't simultaneous.  Meaning your head unit can, in theory and in the right conditions, product a signal equivalent to 52W into one 4 ohm load for one second.  That may not be pleasant to listen to (given distortion) but it can make it happen.  Part of the problem with simultaneous power output (such as all four channels simultaneously) is power supply requirements.  Consider the current required to produce the rated 216 total watts the amplifier IC is rated for, then consider the size of the traces in the amp.  You'd quickly realize the traces would melt and/or catch on fire if asked to supply that much current.  As such, the actual total power output of all channels simultaneously is about the amount of one channel.  in your case, that is 52W divided by 4 which is about 13W per channel.  Even then, distortion is high, so the typical usable (i.e. pleasant to listen to) is about 5W per channel.
So why can a head unit seemingly get "loud" on speakers?  Part of that relates to the sensitivity of smaller, cheaper speakers.  Those lightweight cones move more easily and with sensitivities near 90dB at  1W @ 1M means that at the listening position you could achieve around 100dBA per speaker.  That will seem pretty loud in a vehicle with the windows up, even if it doesn't sound very good because the amplifier distortion is high and the speakers are inexpensive or not ideally mounted.
Quoted for notification purposes.  Hopefully the info above helps.  Feel free to ask additional questions.
You can try. Touch both wires together before connecting them to the speakers. If the HU didn't go on protection mode or burn a fuse, you should be good. (Leave it connected for 5-10 mins to see if it'll burn the fuse.)
not recommended. very ghetto and risky. just buy a 4 channel dual amp(or better, just mentioned this amp because its the cheapest route), power/ground and some rcas and call it a day
586
465
857
HiFiFan15
HiFiFan15
youdoofus
    Apr 28, 2024
    Apr 28, 2024
