need help with my T1
RollinRemz05
Right now i have my Rockford T1 in a 3.5 cu ft ported box. Im not getting a punchy bass at all. If i put it in a closed enclosure what do i need to take into consideration? The Rec. cu ft for a closed enclosure is 1.25cuft. I plan on it being inverted also. The specs are:
Size 12"
Impedance 2-Ohm x 2
Power Handling 600 RMS
1200 Peak
Sensitivity 86 dB
Motor Size 124 oz. double stacked
Voice Coil Diameter 3" anodized aluminum
Speaker Connector Dual 8 AWG slot load
Mounting Depth 6.625"
Rec. Sealed Enclosure 1.25 cu. ft.
35.4 liters
Rec. Vented Enclosure 2.25 cu. ft.
63.72 liters
Tuning Frequency (vented) 40 Hz
Shipping Weight 30.6 Lbs.
(13.9 Kg.)
thanks.
Size 12"
Impedance 2-Ohm x 2
1200 Peak
Sensitivity 86 dB
35.4 liters
63.72 liters
(13.9 Kg.)
thanks.
You answered your own question. The recommended ported box size for that sub is aparently 2.25 cubes, while yours is 3.5 cubes. Going larger will increase low freq extension and hurt upper extension.
Your ported box design seems to be the problem, not the fact that it IS ported.
RollinRemz05
RollinRemz05
Toms River, NJ
audioholic
