Are the kicker 2 ohm or 4 ohm? Specs on that amp?
4 ohm and the amp specs are
Amplifier Type MONO BASS
Amplifier Class D Class
Full Range Digital Amplifier Yes
Load Capability 4/2Ω Stable
Low pass Filter Yes
High-pass Fliter No
Line out No
Speaker level Input No
Maximum Power Output (4ohm) 1200w
Rated Power Output (4ohm, 14,4V) 1200w
Rated Power Output (2ohm, 14,4V) 1339w
Rated Power Output (1ohm, 14,4V) N/A
Bridged Power Output (4ohm, 14,4V) 1200w
Rated Power Output (4ohm, 12V) 787w
Rated Power Output (2ohm, 12V) 1114w
Rated Power Output (1ohm, 12V) N/A
Rated Power Output (1.3ohm, 12V)
Rated Power Output (.5ohm, 12V)
Low-pass Filter N/A
High-pass Fliter N/A
Input Sensitivity 140mV
Signal to Noise Ratio 70dB
Frequency response (+0dB, -3dB) 10Hz - 302Hz
Dimensions (WxHxD) 18-11/16" x 12-5/16" x 2-3/8"
