need help with my EDEAD
Clean the surface first, if its not that bad water and paper towels will do. Then just cut the mat into pieces to fit on the surface you're applying it to making sure that the adhesive side is sticking to something. To ensure that it adheres well, use lots of pressure such as a roller and you can also use heat especially if it isn't very warm out. Better to apply more pressure than less, and giving it some heat usually helps too.
- Luke
yup hair dryer works wonders!! but watchout heating it up too much cause it will be really hard to remove it lol. I did 2 layers in my cars trunk and it is amazing very solid. Yea basically you just place it right over top of the old, make sure you heat it all up after your apply it all, it will help the final set.
Lol, do you like all the silver coating you get on your hands and fingers when you put it on? Its a pain in the bum bum, but it is really nice stuff
Hey Guys,
I need to Edead my car too, I have the mat. So a heat gun would be too much heat? A hair dryer will suffice?
A heat gun will work too, that's what I used. Just don't go over board with the heat. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
phsballin4life
phsballin4life
sc
232Stanger04
