Need help With Kicker L7
Since no one else has, I will chime in...
Main question would be "What is your budget for the amp?"
This configuration will allow you to throw more power to the sub:
If you get a 2ohm sub you can wire it 2ohm or 1ohm but your amp will have to be stable at 1ohm
This configuration can only push the sub at 2 ohm, no lower:
If you get a 4ohm sub can be wired at 4ohm or 2ohm.
So, depending on your amp budget will depend on your outcome...
Hope this helps
If you are going to get 2, go for the 2 ohm because that way you can wire them at 2 ohms stable on a single channel amp. Otherwise you will need a 1 ohm stable mono amp (usually more expensive) or a run the subs at 4 ohms on a dual channel amp (also more expensive and running at 4 ohms reduces your rms and peak wattage delivered to the subs).
dip2set
dip2set
Hartford,CT
43de
