john.mulvehill
Hello,
I purchased the JL HO112R-W7 (12w7 in a ported box) and the JL 1000/1 v2 slash amplifier to go with it. Both of these products were purchased new. I had these products installed at a local audio shop. I am using 4 gauge wire to hook up the system. After the system was installed, the bass was very minimal. I have read lots of reviews about the 12w7 and have heard lots of things from people who have owned it about it being great. Since I could not feel much bass on my back or any other part of my body, I assume something is wrong with the setup. Both the sub/enclosure and amp are new.
The audio technicians thought it might be because there was a line out converter (to RCA) that was remnant from my last system. My last amp didn't take actual speaker wire inputs so a line converted needed to be used to convert to RCA's to into that amp. On that last system, that JBL amp had the gain turned most of the way down and the system still pounded way harder than the new JL system is (even though the old system cost about 4 times less). I think this must be due to the JL system being set up wrong. When I would turn up the volume on the factory head unit, the bass would increase in a correlated manner (the louder the volume, the louder the bass). However, in the new JL setup, the bass just turns on at a low level and does not seem to increase as the volume on the head unit is increased...
The audio technicians think this might be due to the line converter malfunctioning but the line converter was working fine just last week in my old JBL setup. Also, I do not think the head unit is the problem because that ran the old JBL setup just fine. I need to go back to the audio shop on Monday at 4 pm so if you could give me some insight into the possible problem, I could have them try some things out.
Right not even with the 1000/1 amp turned all the way up, the remote bass boost all the way up, and the head unit turned up very loud, the bass is not anywhere near the level it should be..
Any other comments or help would be terrific.
Thanks!
John
Thanks!
John
