Need Help with headunit install
There is probably some trim around the radio. Just use a screwdriver, and carefully remove it. And then there should be screws, you take out.
But im not quite sure, never worked on an astro
NO NO NO. I have a 97 Astro. The trim goes from the drivers door to the other side of the radio. It just pops off but you will need to move the shifer out of the way. Its kind of a pain to get to piece out of the way but it will move. There are no screws that hold the radio in.
do you have any pics of your dash taken off? Also do they make a dash kit for it? I didn't seem to find one only the harness for the adaptor. Oh and I need to change his antenna to I just found out. BTW THANKS!
GreekPower
Big Pun Customs
GreekPower
Pittsburgh,PA
GreekPower
