need help with dual 2 ohm on a 850.4
you can't, you need two DVC 4's for a 4 ohm final load. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
with two DVC 4's
with two DVC 4's
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
He can't power each driver seperatly off a bridged channel?
can I just wire each coil separatly for the 2 ohm load?
NO!//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Let me explain why...
By doing that you would need to match the gain accurately 105%. If it is off by even .01 volts then it can cause problems. You don't want to send mixed signals to the sub.
And wiring it bridged @ 4ohms is the same damn thing(same power). Just safer, so why would you not do it?
doh...4 channel, thought itw as a 850.2 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
good catch //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
miked_mad
buick member
miked_mad
h-town,tx
93 saturn sl2
