If i wired 2 speakers to 2 channels , that would be too much power. I just ordeted another sa15 and this is the amp i have pushing the one u have now so i thought if it would work that'd be great.
Musical power is dynamic. That amp would be fine powering two speakers per channel, left and right. End power delivered to the speakers depends on gain setting, volume control, and supply voltage.
Two 4 ohm speakers in parallel is 2 ohms
Four 4 ohm speakers in parallel is 1 ohm
In the end, you want to maintain stereo separation, left and right... Assuming these speakers are front/rear, left/right - you combine front right and rear right together on one channel fed by the right HU output, and you combine front left and rear left on one channel fed by the left HU output.
Any 2 channel amp that is 2 ohm stereo stable, or any 4 channel amp can power the four type-R speakers. How loud you can play them is determined by the amplifier power ratings. 50W is fine, 200W is fine, 400W is fine considering the power rating does not mean that is how much power the speaker will see, just how much it may possibly be able to see for a musical peak, given volume, gain, and supply voltage align to allow it.
