CleMike
I had installed my own system 4 years ago and just last week my amplifier died (isolated to amplifier).
Since then, I did some research and got really into wanting to make my system sound the best it can with the setup I have. I realized that my subwoofer ( Apline 12) which is a dual coil 4 ohm, was actually wired in series which output 8 ohm. So this time, I wired it in parallel which should output 2ohm. The new amp that I bought is the Alpine MRV-M500 Mono . So I was thinking, man all these years I was wasting potential power by wiring it in series, and thought this new setup would sound a lot better. After hooking it up, it sounds worse. It seems like my bass is distorted or something.
This is my head unit: Sony Xplod
So here are my questions of possibilities for the **** sound:
1.) When I hooked my sub coils in parallel, the wires that came with the sub enclosure that go to the outputs look about 14 gauge? But I used 12 gauge wire to make the parallel connection from the left negative to the right negative and from the right positive to the left positive. Does it matter that I used different wire size for that?
2.) I have 4 Kenwood aftermarket speakers installed (KFC-1362s). The speakers themselves (when my amp was off) sound decent but the bass they produce sounds like absolute **** and ruins the sound. Is this normal? The speakers that came with the car sounded fine without any subwoofer or amp hooked up.
3.) I was thinking since my speakers base sound like **** I should put a high pass filter for just my front and rear speakers, and a low pass filter for the subwoofer. I read that I should only use either the filter on the amp or on the headunit but not both. My head unit has LP and HP but my amp only has LP. I was thinking what if I set my headunit HP on to 100 and my LP on the amp to 80? Would that make my speakers not play low bass notes and my subwoofer not play high notes? Or is that not how it works?
Please let me know of anything you think could be my problem. I thought I had it all figured out and have been messing around with it but maybe I need a new headunit? Maybe I blew my sub? Maybe my speakers are blown? I'm not too knowledgeable on all this so hopefully more experienced guys can help me out.
