need help wiring
10" Dual 4 ohm Shallow Mount Prime Stage 2 Series Subwoofer Power Handling: Peak: 400 watts persub RMS: 200 watts per sub Impedance: 4 ohm Mica injected polypropylene cone Black raised surround Linearspider with 16 AWG woven tinsel leads StampCast basket with integrated spider venting CEA-2031 Compliant accurate power handling rating Designed for use with sealed and vented enclosures High temperature voice coil Integrated PVC trim ring Anodized aluminum voice coil former Frequency response: 45-250 Hz Sensitivity: 82 dB Mounting depth: 3-7/16"
Hope this helps you, so I was wondering if it wwould run both, and if the amp has one connector dose that mean it will only un. Sub?
Ok thanks and soory if im in wrong section, and so I can run the amp strait to the two speakers, anyone hae a wiring diragram that they could lend me?
I don't not have the amp, so any suggestions, I have like 125 to 150 to spend on a amp,for this set up? And do you know what wire and what cords I will have to run for the subs and the amp?, and yea would really appreciate a diagram, imma look for one
here is a link to how you can wire the voice coils up on the subs.
Subwoofer Wiring Diagrams, Two 4 ohm Dual Voice Coil (DVC) Speakers
You just gotta find an amp that does 400 to 500 rms at either 1ohm or 4 ohm, which a decent 2 channel amp bridged could do it at 4ohm or a mono block at 1 ohm.
rj22beast
rj22beast
houston
rj22beast
