Need help wiring
rdlyn13000
I have a pioneer HU with only 2 RCA Pre-outs on the back. I'm going to be running 3 amps, 2-1000/1 for the subs which I'll have 1 set of RCAs from the HU to the master amp then jump to the slave. Now I only have 1 pre-out left but I need 2 sets for the front and rear speakers on the 450/4. What do I do?
to make life much more simple, and trouble free..id get a 3 way xover..you can find them under $50,or even a preamp eq would work just as well..thats what i myself would do/buy
Ok I'll look into that, if you find any links to one for sale let me know! A buddy thinks we can use RCA splitters but I don't see how that will work?
i havent found out how to attatch links on here yet, but go to ebay look up xovers...it doesnt have to be expensive..most shell out more voltage than the hu..coustic makes a decent one cheaply priced...your rear will be switched to sub, and you will only have front, so fading will be off./no rear fade, sub only,and front left n rt,is all you will have..xover will be a no brainer, and less stressful, and can enhance the signal rather than flat from hu/amp
well, they used to be a little cheaper...but for the money, and adjustments at your fingertips at Sonicelectronix.com a din size preamp eq..free shipping-Cadence CEQ-773 7band eq, that will work perfect, and adjustable at your fingertips for $44.99 free shipping,brand new, with warranty
Thanks, I'm going to do some searching around...
To post links you just highlight and copy the the page up in the bar where you type web pages then you just right click and paste right here where you type your post
rdlyn13000
rdlyn13000
White Bear Lake
rdlyn13000
