How am I the new r-tard of the year...... Be I have to show a f***ing video... or are ya'll 2 individuals too ill-minding to see?
I mean, seriously!
Ex:
A interfire 700.4 is ~Approx. $220 BNIB Shipped.
(4) 6.5s & (4) 6.9s
TAKE 1 set of the 6.5s.... (2) Speakers...
1) + on speaker #1 & - on speaker #2 ( twist and crimp cap those together )
2) The remaining + and - .... Leave those ran separate ( used later on )
Take Next set of 6.5s... Do the same THING.
Take the 6x9s... DO THE SAME THING.
NOW!
- You shoud have 8 WIRES running out. ( 4 +'s and 4 -'s )
* Each set is at 8ohms *
Now you run them PARALLEL
1) Both 6.5s Positives together & Both 6.5s Negatives together.
2) Both 6x9s Positives together & Both 6x9s Negatives together.
2) Bridge those on the amp
* 6.5s on channels 1&2 ... 6x9s on channels 3&4
* THIS IS A 4ohm load on EVERY CHANNEL ... My amp runs more efficient and gets ALL off it's power... * - MOST 4-ch amp do...
NOW FOR THE TWEETERS....
It doesn't matter how you run them...
You can twist all of the tweeters positives together and the negatives together and run them ALL off of channel #1 ( NOT BRIDGED like the 6.5s or 6x9s ).
Now for you lames....
1) The tweeters that he has ARE NOT component tweeters.
2) Excuse me if I explained it wrong... THEY DON'T HAVE A STABLE OHM LOAD...
3) The tweeters that you are referring to are like Memphis PR-1s ... Flush mounts, titianium domed, etc. one... THEY HAVE A 4OHM load... because they can play ACTUAL music.
* Music - meaning words...
4) Cheap 350w tweeters ( Power acoustik, MCD, NT Power, PO-155, whatever. ) don't play at the frequency that words are noticed & associated with.
Question: What do you hear @ 25k - 50k?
Answer: Whines including ticks, statics... even churps
... So don't bash me on $hit that you aren't literally knowledgeable about.
