crashprime
I am installing 3 items in my car:
1) JBL MS-A1004 4-Channel Amplifier (internally fused at 60A).
2) JBL MS-A5001 Monoblock Amplifier (internally fused at 80A).
3) JBL MS-8 Sound Processor (internally fused at 25A).
I am using 2 KnuKonceptz KNF-23 fused distribution blocks to help me keep everything clean. One is fused for each item to wire up to the positive terminal (30A for MS-8, 60A for 4ch, 80A for Mono). The instruction manual suggested/required that there was inline fuses in addition to the internal fuses.
The other is just installed with "links" in the fuse section to use for ground distribution.
I plan on using 0ga wire to the positive battery terminal to "feed" the fused distribution block, and then from each of them I'll be using 2x 4ga (4ch & mono) and 1x 8ga (for the MS-8). Same deal for the ground.
My primary (only) battery is in the trunk of my car already, so my question is, how long can/should I run the 0ga for until I put the distribution blocks into action? I've read that I am supposed to put the blocks no more than 18 inches from the ground point/battery ... but I feel like maybe running a longer 0ga and shortening up my smaller gauge runs would be "better"?
Any advice here? All said and done I don't think there's going to be much more than 10ft of wiring.
