Need help tuning a amplifier.
I VIK I
I am trying to set the input sensitivity I did use the right cd. Sine wave at 0db 50hz turned up 3/4 of the way. I only seem to be getting 16.2 V AC out of the amp when I test it? What am I doing wrong? I disconnected the wire from the sub side. its still connected to the amp. Whats going on here?
Also what would happen if I connected the - wire to the positive and positive to the neg while running the speaker wire to the speaker box from the amp?
Sorry newb ? but my last system was a Sony....
Currently,
13w6v2
500/1
Impendance should be 2 Ohms at 31.6V if I am correct.
Dont mix positive and negative. Are you running one sub, or two? Do you have them bridged? What do you have your other settings on, such as the lpf and hpf? Check to see if its on hpf.
Ok did that for some reason My max Ac voltage is comming up as 25.38 the input sensitivity doesnt go any higher and Im supposed to take it up to 31.6 V
Output Mode: Full Range
Filter Slope 12 Db
Filter Freq 65
Filter Mode LP
Infrasonic Filter On
Infrasonc Freq 30Hz
Q 1.6
Center Freq 60
Boost +4
Bass Eq On
Mode/Slope 12DB
Filter Freq 80
Input Voltage Low
Signal Sensing OFF (Because I have it wired to a switch)
Anything seem wrong here?
Input sensitivity is as high as it can go and my reading is 25.38 Volts
Everything is at Zero on the Hu and now im back to a reading of 15. something when the input sensitivity is on full my settings are listed above. what should I do?
Correct sir Disconnected from the speaker side the wire is connected on the amps side. It is a stock HU. I had nice readings with the bass turned up from the HU but as soon as that goes to zero my max reading is like 15-16 watts
I VIK I
I VIK I
Long Island
boomzilla
