Need Help, Sound Digital SD5K Clipping BAD!
ok ,then unhook your woofers ,turn the gain all the way to the left, thenturn your deck up to where you like to listen to it loud.then start to turn your gains up, when the clipping light starts to come without blinking,back it off just a little.turn your system down then off hook your woofers back up and enjoy.this is what i was told to do by murilo ....... just for your info there is no such thing as a stock gain setting
The knob is all the way left, when I turn my volume up more than 5 or 6 on the head unit it starts clipping, u know there is no stock gain setting
my voltage is sitting at 14.3 idle so that's fine.
Crossover is set from the h701, I have it set from 25-80hz
Make sure the sub out is way down on the 701 before you set your gains and see if that helps.
I have an o-scope and I've tested my sub out on my 701 & it clips above 5 for some reason while all the other outputs didn't clip at all. It was clipping the input of my sub amp so I lowered it to 2 and set my gains from there and it works wonderfully. I've had it for years, explored every setting. Not sure why this is but I've tested it multiple times and get the same results. Could be what is happening with yours.
Thank bro, I'll try that
John
This thing is driving me crazy!
I have the bass setting on the H/U at 0 of 15, gain on the amp all the way counterclockwise, and it's still clipping at any volume above 5 or 6 on the H/U.
I've tried removing the 701, and the amp is still clipping at very low volumes.
I've also tried switching inputs from sub/center to rear on the 701, and it's still clipping
help please
John
jonny101abc
SOCAL Stang-Man
jonny101abc
San Diego Punks!
JHughes
