Need Help Quick!
Medinal7
i wired in my head unit into my 03 f150. and when i did i guess the acessorie wire touched a ground or somethin so now that wire is not getting power. when i touch it to the constant it works though. how do i wire this to something else to get power besides doing a switch?
if it's not getting power, it's definitely most likely either a fuse or a fuseable link. I would def. try replacing the radio fuses and such regardless if they look alright just to make sure.
But if you can't get it working, you can tie the ign wire into your accessory wire at your ignition harness, or your cigarette lighter if it's a switched power source which I can't remember if an f150 would be constant or not..
Most are directly on the fuse panel cover.
How are you checking the fuses? If you have a multimeter than can test continuity it'll take literally 60 seconds to check'em all.
Medinal7
Medinal7
Springs, TX
93dakota
AJ (ACE)
    Jun 28, 2026
