crazyeye
Hi. I need some help with a car stereo upgrade. I recently purchased a 1998 BMW 750il. While the stock stereo is pretty bad, it is all integrated into the onboard computer/navigation system, etc. so changing it really isn't an option. My plan is to change everything up to the head unit. Here is the equipment that I currently have:
Focal Utopia 136w 5.25 components speakers (http://www.focal.tm.fr/gb/car/utopia/136w.htm)
MB Quartz QM215.61 5.25 components speakers (http://www.mbquart.com/en_US/products/prod_detail.asp?isArchive=&cat=auto&series=q%20series&strt=1&model=QM+215%2E61Q)
xtant x603 - 600 watt 3 channel amp (http://www.xtant.com/html/products/X603.cfm)
_________________________________
I still need a subwoofer and I'm trying to decide between 1 JL Audio 12w7 or 1 10w7 or 2 10w6.
Finally, I'm trying to decide the best way to power this system. Can I use the xtant x603 to power the entire system? Will that be enough power for the subs? I'm a bit confused by how a 3 channel amp works and how different ohm settings result in different power outputs. The Xtant site says I can do 150x2, 300x1 at 2 ohms. I think the MB Quarts will only run at 4 ohms so, uhm, what does that mean exactly? Am I best off using the Xtant amp to power the focals up front and the sub and get something else for the rears? Should I use the Xtant for the front and rears and get something else for the sub? Should I use the xtant just to power the subs and get something else for the front and rear? Should I just sell the xtant and get a different amp or amp combination? If so, what would be ideal? My impression is that the focals need a lot of power. Also, am I better off putting the focals up front and the MB Quarts in the rear? Am I making a mistake by limiting my sub choices to those I mentioned? Is there something better I might consider? Finally, (last question, I promise) any suggestions as to how I can find someone who really knows what they are doing to install all this? I live in central NJ (near freehold). I'm sorry if these are ridiculous questions. I'm new to this stuff.
Thank you so much for taking the time to help out.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
