need help (pulling hair out)
Lo Taco
ohio
Im having a weird *** problem with my system its a 400w amp with 4 channels its a soundstorm force and the subs are 2 rockwood force 1's that are from like 1980 lol anyways i have everything hooked up with a brand new 500w wiring kit its grounded to the ****** tunnel in the EX cab and grounded well when i put the power wire on the amp it has a spark and blows the fuse when i hook it up and change the fuse it blows the fuse when i hook it up change the fuse and then put it on the battery it blows the fuse and im pissed lol help me asap if you can thanks!!
I say double check all your wiring. Make sure your power wire has not rubbed through anywhere and is grounding out. Check to see if they are hooked up correctly on your amp. (polarity, remote)
Make sure you put a fuse in-line as close to the Battery as possible.
Lo Taco
Lo Taco
ohio
Rattlebrain
