Need help please
I have a 2012 chevy malibu. I do not know what to go with. 2 10" or 2 12" or 1 10" or 1 12" sub. I listen to mostly rock, dance, a little rap. I have will be putting in the morel elate for components not sure 3-way or 2-way and morel tempo in the back. I will be running a jl hd 600/4 for the highs. And a jl hd 750/1 or jl hd 1200/1 for the subs, i have both. Hopefully one of you pros can help me. it has been 20 yrs. since I played with this stuff. Things have really changed for the better! Thanks!!
better can be had than the w7 for the money
Axis Driver | TC Sounds
for example. jl has a great product but for the price you are paying for advertising and name along with it
PSI Car Audio | Subwoofers in all colors and flavors!
you may want to get dave at psi car audio to build you a sub. he was one of the original engineers of re audio. amazing subs, he is on caraudioclassifieds.org as a vendor
(PSI Car Audio) - Car Audio Classifieds
JBL W12GTi MkII (Q12GTiMk11) 12" Dual 6 ohm GTi Car Subwoofer
RE Audio XXX12D4 (XXX12D-4) 12" Dual 4 ohm XXX Car Subwoofer
Boston Acoustics SPG555-4 (spg5554) 13" Single 4 ohm SPG Car Sub
Fi SP4 Series Sub Woofers | Fi SP4 Subwoofer
Q12 - Fi Car Audio Store
the other amazing engineer of re audio. amazing subs custom built to order
how much trunk are you willing to depart with? To get a good sounding and solid bottom end that will keep up with your mid/high power, I would strongly suggest two 12's ported on the HD 1200/1 (sweet amp, btw).
^^^This, but it will depend on how much space you have available for a box. Have you taken measurements yet?
if you dont mind taking up half your trunk 2 12's, if not that one really nice 12 depends. only other option would be the 2 ba spg 13's they only need 1 cube sealed and get some passive radiators direct from them. this is what i did for my install i can pst pictures in a sec
2 cube is this size of a box in my grand prix which is the general size you want for a single 12 ported. so 2 12's would take a box twice this size plus port area. i have the 2 boston acoustics i recomended and 2 spg-tr's tuned to 30hz. so i get a small box like mine plus the output of a ported box. i love me setup for a little under 660 bucks for 2 subs and 2 pr's and its amazing. it was the loudes cleanest setup i figured for a 2 cube box to save trunk room and weight
Boston Acoustics SPG-TR TunableRadiator Oval passive radiator for use with Boston's SPG555 subwoofers at Crutchfield.com
You can always do two seperate boxes as well,one on each side of the trunk too.Two heavy 10s, in approx 1.6 cu ft box ported @30-38 htz will sound fantastic,better up to 2.0 ea.I think like an FI SSD 10 would be great,to run in a pair
---------- Post added at 12:50 AM ---------- Previous post was at 12:49 AM ----------
Even 1.4 ported would be just fine
Bones73
Bones73
Chester County,PA
audiobaun
NorthFramingham
    Jun 30, 2026
