Need help please with box ports..
busapro1983
hello i have 2 Soundstream X3-182 i built a box that is....
25 height
49 width
22 depth
i want to go areo ports round ports can anyone help me with the port size and info please too get 33hz
this is the subs info if you guys need it..thank you very much..
Subwoofer Specifications
Subwoofer Size 18"
Peak Power Handling 11000 watts
RMS Power Handling 7000 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 2 ohms
Voice Coil Diameter 4"
Sensitivity 92.9 dB
Xmax (millimeters) 20 mm
Subwoofer Design Round / Circle
Main Cone Color Black
Woofer Composition Paper
Woofer Surround Foam
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Minimum Ported Box Volume 4.00 cubic feet
Optimum Ported Box Volume 6.00 cubic feet
Maximum Ported Box Volume 8.00 cubic feet
Top-Mount Depth 10"
Cutout Diameter 16.75"
Electromechanical Parameters
Free-Air Resonance (Fs) 32.68 Hz
Equivalent Compliance (Vas) 2.401 liters
Total Speaker Q Value (Qts) .419
Electrical Q Value (Qes) .454
Electrical Resistance of Voice Coil (Re) 3.83 ohms
Mechanical Q Value (Qms) 5.456
(2) 8 inch ports 12 inches long will get you 33 hz
That's 33hz with 8sq in of port per... That's going to be port noise out the ***. You need atleaste 12.5 inches per cube.
Two 10in tubes 27in long would be 33@15sqin per. Or three 8in tubes 24in long is 33.5@14sqin
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
952
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
953
644
712
busapro1983
busapro1983
orlando
busapro1983
    May 16, 2024
    May 16, 2024
