Anyone good with enclosure specs I ****
ccapital83
NY
I need help. I want to put my Nvx Vcw104 in the largest sealed box I can before it will deteriorate sound. I tried the popular program and it was way above my brain capacity. anyone willing to take the time to run numbers for me? Nvx recommends .75 cubic feet sealed The manual states .75 online states .65 called Nvx they said .75 is correct not .65. I am hoping its safe to go a little larger like maybe 1.10 after displacement? here are the ts they give for it, Thanks to any help given //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Subwoofer Series:
VC-Series
Subwoofer Size:
10"
RMS Power Handling:
750 watts
Voice Coil(s):
Dual
Impedance (Per Voice Coil):
4 ohms
Voice Coil Diameter:
2.5"
Frequency Response:
20 - 220 Hz
Sensitivity:
85 d3
Xmax (millimeters):
20 mm
Subwoofer Design:
Round / Circle
Woofer Composition:
Woven Fiber Pressed Paper Cone
Woofer Surround:
Foam
Magnet Structure:
Triple Stacked
Subwoofer Grille:
No
Recommended Enclosure Type:
Ported / Vented or Sealed
Optimum Sealed Box Volume:
0.75 cubic feet
Optimum Ported Box Volume:
1.0 cubic feet
Top-Mount Depth:
6"
Cutout Diameter:
9.61"
Free-Air Resonance (Fs):
31 Hz
Equivalent Compliance (Vas):
24.96 liters
Total Speaker Q Value (Qts):
0.45
Electrical Q Value (Qes):
0.526
Electrical Resistance of Voice Coil (Re):
6.4 ohms
Mechanical Q Value (Qms):
2.981
I have a kicker cx600.1, jbl-ms-a5001 and alpine mrx-m55. Id be running either of them at 2 ohms. I can use the smallest rms one if that would help me use a larger enclosure?
use the most powerful sub amp you've got. go with specs. they are there for a reason. otherwise.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=running%20bigger%20sealed%20boxes
google is your friend.
yes google is good i read almost every one of those websites. Im asking if its safe to go a little larger. On those site people say manufactures tend to recommenced smaller than allowed on purpose I was just wondering if I can run larger than .75
lower power limits. bigger box.
bigger power limits. smaller box. so yea. your good at 1.01
Thanks man I have a 1.17 before sub displacement I might put something in the corners or tripple caulk all the seems to take up more space. I can run the smaller amp also. appreciate the help!!!
ccapital83
ccapital83
NY
ccapital83
