Need help picking out 4 12s!!!
Okay. I have a few more questions then. With 3 subs how would I wire them down to 1ohm? :xThe absolute largest box I can go with in a 6.67 cu ft.
I wanna be louder than my friends 1 15 L7s because he always says nothing is louder.. >.
6.6 is before displacements? If so then you can do 2 maybe 3 subs and some precision ports(maybe a slot port if room allows).
If you really want to up set him, you can be louder with a single 12 if done correctly.
Not going to recommend specific subs, but I can tell you that a lot of the online brands will easily get louder than that L7 of your friends. It really just depends on your budget, also how well you build your enclosure and if you stick to ported instead.
3 dual 4 ohm subs can be wired to either 2.67 ohms or .67 ohm , but really depends on the subs. i have a horn ported box with 1 ascendant mayhem on a dc 2.0 2000 watt amp that will slam all over your friends l7 15 all day long
Not that hard to beat 1 15 when you're talking about multiple drivers. Actually there are plenty of 15s that will out do that L7... So do you want multiple subs or 1 sub that can do what you're looking to do?
Well, I already have a mechman 270a alt coming. Im buying a 16v battery soon. And I havent decided between MA 4000d, 2 saz1500, or a mojo4000.
Hes running 3000 watts from 2 kicker amps..
Please elaborate. I wanna be LOUD. lol.
Ill do multiple. I just thought I could fit 4. But that was my crazy fantasy. :p
He has 2 15 L7's btw..
3 dual 4 is 2.67 or 6 ohms not .67
3 dual 1 would give you the .67
I like sa's products, it looks like they bring alot into the car audio. Mojo just scares me because I googled that amp and everything that popped up was "broken mojo amp repair" lol.
He has 2 15" L7s
Sorry for the confusion.
back on topiccc. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Which 3 12s should I go with?
Looks like
sa12
Skar vvx12
Other?
Not looking to spend alot on subs, less than 1000 would be great.
35thStangGT
35thStangGT
United States
SKAR-MaliBOOM
vegang
vegang
