need help pickin a amp have any ideas
zane72288
ok i have 4 alpines
Sensitivity: 84 dB
RMS Power Range : 500-1000 Watts
Peak Power Handling: 3000 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 24 Hz
High Frequency Response: 200 Hz
Diameter: 12 Inch
Features
Type-X 12" subwoofer with dual 4-ohm voice coils
Designed and Engineered in the USA
Hidden Screw Gasket
Gold Plated Insert Terminal Block with VC Connection Jumpers
One-Sided Terminal Layout
Massive Triple Stacked Strontium Magnets
FEA Optimized High Excursion Injected Santoprene Multi-Roll Surround
FEA Optimized Mirrored Progressive Nomex Spiders with Integrated Tinsel Leads
FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology
Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting)
Integrated Spider Landing and Heat Transfer Plate
Dual Voice Coil Design, 4-Layer High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former
Custom Cast Aluminum Frame
Carbon Fiber/Aluminum Honeycomb Parabolic Cone
top-mount depth: 8-5/8"
sealed box volume: 0.65-1.25 cubic feet
ported box volume: 1.0-2.0 cubic feet
does anyone kno of a amp that can power all 4 i and any ideas of other things i need to get with them also wat box would best for them
zane72288
zane72288
houston
MisterGrubbs
