Need Help on Wire Gauge
lektrik
I currently have 4awg running with this amp Amazon.com : Alpine MRP-F300 4-Channel 300 Watts Amplifier : Vehicle Multi Channel Amplifiers : Electronics.
I want to add this amp Amazon.com : BOSS Audio R1100M Riot 1100-watts Monoblock Class A/B 1 Channel 2-8 Ohm Stable Amplifier with Remote Subwoofer Level Control : Vehicle Mono Subwoofer Amplifiers : Car Electronics.
My question is: Can I used the current 4awg power wire, run it to a block, and power the Boss amp to run my single 10" sub?
Thanks.
p.s. I just want to avoid ripping my car apart if my 4awg wire is enough to power both amps without any problems.
tbh, i don't really mind if it doesn't put out that much power. i just want a little thump with this sub Amazon.com : Pioneer TS-SWX251 10" Flat Subwoofer with Enclosure 800 Watts : Vehicle Subwoofers : Car Electronics . lol, that's why all my gear is from amazon rather than an audio dealer. thanks for the help!
That's a 4 ohm sub and at 4 ohms, you'll be lucky to get 100W out of that amp. Chances are, it probably won't last. Can you do $100 or so? I'll find you something.
won't last? i can shell out a $100. i'm just not aware of what products are good anymore. lmk. thanks.
when i purchased the sub, i went with the "those who purchased this item also bought this..." //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
lektrik
lektrik
United States
CSCStang
