Need help on port calculation
Bigrick31
Carpe Diem
ok im trying to figure out the dimensions of a 3" peice of pvc pipe so i can port a friends box. so far i have figured out the box has an internal volume of 2.7^3ft before displacement and 2.54^3ft after displacemet. then we figured 32hz for the tuning as thats what RE recomends for a 12sx. and wed like to use 3" pvc can someone tell me how to use this info to figure out the length of the pvc? the answer would help but really i want to learn how to do it so if someone could teach me it would be greatly appretiated
with the Port Length Calculator off the12volt.com you just add the info you have into the calculator and it does all the work with 2.54^3ft box with 2 3" ports the Port Length wood be about 12.45" long each I wood not use just one port or you might have port nose with the 2 you shoud be fine but i am not shure on that i have naver herd the sx befor but with my 12"L7 i had 2 4" ports becaus with one i hade some port nose now i have the L7 in a slot port box and it is loud i hope this info was wat you wer looking for
Bigrick31
Carpe Diem
Bigrick31
Mid*Cal
spljim
michigan born
    May 14, 2026
michigan born
    May 14, 2026
