Need help on hooking amp to mids
projectnutz
yea, imma a noobie, but i need help on hooking up an amp to my two front speaker. I'm using a ppi 2240 to power two re audio 6.5c. I got everything figured out, but i just dont know where to hook up the remote wire, beause i'm already running another amp for my woofer on it. should i go ahead and hook it up to the same wire?
yea........ there are other options but what exactly are you searching for???? hook the wires together.....
are you having a problem with remote voltage??? why do you want other options if you dont have a problem... If you do have a problem, which you have not indicated,, you can use a relay...
What are you trying to do??
Well i tried hooking up all the remote wires together but whenever i mess with the gain, you can notice the sub go down also.
if you don't hook it up to the remote, any 12v source from the ignition will work just be careful which one you splice into... i made the mistake of using the 12v relay to the light thats under the steering colum in a prelude one time for the head unit itself, and if the car was off the HU was off.... if the car was on the HU turned on so i was like ok perfect... and then one day i realize that as soon as i opened the drivers door the HU turned on, no ignition necessary lol it was cool cuz as soon as i opened my door my radio turned on for me, but it could have been bad, so just be careful lol
projectnutz
projectnutz
Arkansas
spencer321
