Need help on deciding two subs 3500rms+
zach504
I am looking for two 15s or 12s that are at least true 3500rms going into a trunk of a 2001 mustang, I wouldn't mind getting 18s but I have trouble fitting a single 12 in my trunk. I'm in the price range of maybe $1000-1500. My first choice was going to be two Sundown Z-15 v4s. Any Helps Appreciated.//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
My Setup is or will be:
Alternator: Stock 105amp(Upgrading to Ohio Generator 300-370amp later)
Wire: Sky High double-zero gauge (big 3 upgrade)
Amplifier: Sound Qubed Q1-3500D.1
Batteries: TWO XS Power D3100's wired with 00/0 gauge
What are those a picture of? The soundqubed 12s are nowhere near enough power for what im lookin to push.
Yes they are! They're underrated. In the right box they will hit super hard and might mess up your trunk latch. If you think they can't handle the power, see if they will let you get aluminium coils instead.
Lots of ppl and i mean lots of ppl pair up hdc3s on the 3500..its the perfect match ..iwould have ran them but i got a killer deal on the hdc4s...you dont have the room for 15s in that trunk unless u build it in there .so go with 12s
OP you have one 4kw amp, so why would you need 3500+RMS subs????
NO way 15's are fitting, 12's in the right enclosure is your best bet. Off that amp HDC3 copper or alum coils would work. Plenty of other subs out there that will take that amp if you don't want SQ subs....
zach504
zach504
Slidell, LA
Kangaroux
