Need help on Amplifier settings
  • Thread starter hidehide
  • Replies 0
  • Views 638
hidehide
I need help on the amplifier settings since there are no good car audio shop around my area! And I believe you guys will have the knowledge to guide me through.
So I have installed an new amp and speakers, but I feel the speakers are still lacking of midrange.
My setup are as follow:
Speakers (tweeter, mid and subwoofer): Rainbow IL-C8.3 BMW F-Series Front semi – active“
3-way 8 inch (20 cm) Compo Set
25 mm Silk dome Tweeter
Max. 150 Watts
Minimum Amplifier Power: 75 Watts
Frequency Response: 35 Hz – 30 kHz
Amplifier: Rainbow Germanium Four
4 x 105 Watts @ 4 Ohm
4 x 140 Watts @ 2 Ohm
2 x 300 Watts @ 4 Ohm bridged
12 dB High Pass: 15 Hz – 500 Hz (5 kHz Front)
12 dB Low Pass: 50 Hz – 5 kHz
Dimensions (LxWxH): 420 x 235 x 55 mm
And here are my current amplifier settings:
4 Channel
Rear: Gain = Max, LPF= 80Hz, HPF=130Hz
Front: Gain = 80%, X-over is set as FULL, hence no LPF/HPF is set
Phase = 0%
How can I improve the midrange sound? What i'm trying to match is to get the similar sound quality of my home speaker (Bowers & Wilkins Zeppelin Air, which also comes with tweeter, midrange and subwoofer)
Will turning down the treble and bass in my headunit help? Please let me know!
Thanks in advance!
hidehide
hidehide
Hong Kong
hidehide
